9n3 black headliner
I'm after the black trim that's found in the 9n3 gti its for a 5door need everything headliner grab handles light ABC pillars visors ect cash waiting
  • 4 months later...
  • Views 366
  • CorbinOrchard
    CorbinOrchard
    I also wanted a black head liner, asked around some auto-upholstery shops and they quoted me £490 minimum for a fitted headlining!!!   In the end i just took the headlining out and all the o
Bump
Bump
In the end i just took the headlining out and all the other bits i wanted black/slate grey.
I sprayed the headlining and all the plastics with U-POL dark grey primer, then sprayed the headlining with 3 coats of U-POL satin black and the plastics i just gave a couple of coats of U-POL clear lacquer then give it a rub down with some wet/dry sandpaper to give it a matt finish.
Was very impressed with the results,
Ill post some pictures of the results soon.
