g60 brakes on 6n GTi
hello guys need some help here for a friend who has gti and want some g60 brakes in
if anyone has parts reference i need would be great.. calipers,disc etc or any info parts that i need to collect
and he has 2 set of bbs rx2 rims in 15 & 16. will these would fit ones g60 brakes installed ?
Thanks!
  • Replies 10
  • chriskremlin
    chriskremlin
    Hello guys The car is mine, its a 1.6 16v AJV motor 08/99 my disk are in 259x22 For wheels i have rx2 in 15" and rs 764 in 16"so i can use 16" if neccesary.
  • chriskremlin
    chriskremlin
    So if i take g60 carriers and discs,braking will be really better ?
  • chriskremlin
    chriskremlin
    i will try with disc and carrier. I come back soon to give you the result. ty for informations
There are lots of threads on this about what parts u need. I assume it's a 6n 1.4 16v when u say GTI.
If so u can use the standard calipers and use g60 carriers and discs.
I seen a fella running 15" RX2s over g60s on edition but have never done it myself. 16s will fit no problem.
Hello guys
anyone got some advice on this please?
No harm but what more advice do u need. I've given you a rough idea what you need there.
Alternatively as I also mentioned there are numerous threads already on this if you search. If you won't help yourself others will be reluctant to help you.
Chris I assume your car is the European model with the 1.6 16v engine. I'm not sure if you'll need calipers or not. I assume not but the discs are carriers are a definite
ty for informations ;)
Hi guys,
I installed some time ago the discs 280 mm, I had to change the plate to put those in the G60.
My question if I install callipers AUDI S2 dual pistons, should I change the master cylinder?
If so by what model?
Thank you for the info.
up please ;)
Hi guys can someone help me? plz
