GK (big bore) inlet manifold 32/34 DMTL and mounting plate.
Up for sale is my GK inlet manifold. This was an extra on the mk2 GTs. Only available on LHD models due to a lack of space for a brake servo on the RHD models.
I had this on a 1.4 ABD engine and it was a great set up. Such a noticeable difference between this and a standard inlet manifold.
The carb is also in good working, it has been 'de hedgehoged' and the mounting plate has been matched. This would all bolt straight on to your existing 8v engine.
Note that if you're engine has a mechanical fuel pump you would need to blank that off and fit an electronic fuel pump instead.
Message me if you would like any further information or pictures. The last picture shows the difference in the manifold bores.
post-915824-0-43439100-1452949747_thumb.
  • Views 699
Forgot to add the price..
£170 for the what's images and including postage.
Thanks,
George
posted on fb...would you do 150?
not too far away
Why would I need a to blank of fuel pump and fit an electronic one if the head isn't being changed? Also would you be interested in selling just the inlet manifold?
SOLD
