1.0 spi mk2f
H reg 1.0 spi red polo breaking for parts.
All the body panels are battered and dented, could possibly cut pieces out if you're desperate!
Other than that most of the car is up for sale, message me for parts and I will get back to you as soon as I can.
Thanks,
George
  • Replies 28
  • Views 2.7k
Where are you based?
Near Colchester, Essex. CO6
Hi George, do you have an exhaust manifold heat shield?
Would need it posted to Newcastle.
Thanks, Dave
Hi do you have any cable controlled wing mirrors?
do you have a rear bumper and mounting hardware, could you post?? cheers
I will check all of the above and get back to you on Saturday
Cheers mate
How much for front brake carriers and bolts posted?
Dizzy posted how much?
Managed to have a look.
No exhaust manifold heat shield, rear bumper or mounting brackets and no cable controlled wing mirrors sorry there.
Brake carriers - £18 posted
Dizzy - £18 posted
Will PM both of you for address etc
Dizzy - £18 posted
Can you privet message me some pictures pal
Dont suppose youve still go the front struts?
Do you have the ariel. Would need posted to northern Ireland. Also hazard switch if you have it
I am off work this week Wednesday - Friday so I will get all the above parts off, take some pictures and send them to you.
You got a throttle cable and howmuch posted
Hi, don't suppose you've got the rear shelf rubber straps?
Thanks, Dave
looking for the fuel pump and cradle and all the pipes/hoses uncut to convert a carb car to inj, so pref all hoses from front to rear
Edited by steveo3002
Thanks, Dave
Sorry Dave no rear shelf rubber straps.
Hi Steve,
I will have a look at these for you and get back to you on that. Unfortunately not around this weekend so may take a few days before I get around to doing that with work etc.
I can get the throttle cable off it no problem but you're better off going to a local motor factors? I've brought one from there before only a few quid for a new one
Tom,
Still yet to get the front struts off. They are almost done, are you still interested?
No Ariel. Hazard switch is there. Not sure on postage to Northern Ireland. PM me if you're still interested?
Is the handbrake lever still available?
Believe so - yes. Same as a few others not around this weekend and that's when I have time to get parts off and wrap them etc. Will look to get that off for you next weekend
Hi there do you have a drives door ??
Hi, the body panels are all rough drivers door is dented and rusted in the corner. Welcome to pick it up if you want it for free otherwise it is destined for the scrap bin!
Edited by GaB
