heater issues
My heater doesn't blow in the directions its supposed to, for example it does not work blowing towards you are body and on feet I get one warm leg and the other cold. Mk2f 93 are there any obvious problems to look for?
Thanks if you can help
  • Views 670
the wind from thus heater shall bloweth most precariously from within the downward depths of ones thermal differentiated heat exchanger.
or put simply...if it just blows heat from the footwell and the windshield this is normal. it is possible to sacrifice one for the other to re-route the hot air to the main forward facing vents tho
