Parts clear out! Mainly mk2f but some 6n too
All priced excluding postage
Relays £2 each
99 relays £8 each
6N thermostat housing, just been test fitted, comes with 2 thermostats £20
G40 inlet £20
10 mm spacers X4 £20
Radio £20
12596723_10208557724530265_1740503494_o.
G40 boost return £30
12620505_10208557726010302_377283214_o.j
Right side of paving £1 each
Left side £5 each
Sunroof model drain hoses £5 for the set
12562701_10208557746490814_2052970142_o.
Fuel filler neck panel £5
Windscreen panel £10
G40 back box £40
G40 mid section, 1000 miles old, £40
G40 manifolds X2 £20 each
1.0L cat £25, mid section £10
12591974_10208557764251258_1007928495_o.
1.0L engine loom plus some other wires £30
12562420_10208557727290334_1327427965_o.
GT throttle body £15
Cam cover gasket from VW £14
12620611_10208557728250358_1613551077_o.
£1 each part
Ariel has no antenna
£10 each part
Door sheets are in great condition, £10 for the pair
VW1 calipers and carries
Seatbelts £10 the lot
12557119_10208557723410237_495294672_o.j
£50
12557231_10208557713970001_1234687760_o.
Any more info needed just ask
  • Replies 15
  • Views 1.2k
Postage on the 1L mid section?
£10 buddy
Edited by RetroWheels
G40 inlet SOLD
what make is radio please ?
It's a clarion crx56. It came out of my genesis.
Still got a few parts here
Hi,
How much for the calipers and carriers posted please?
PM'd
Hi, Looking for accelerator pedal and two plastic grooets for holding it to pedal box - 86f
Text me to 07825-167702nif available
PM'D
Interested in the backbox pal. Shall I PM you?
  • 11 months later...
Hi
I'm after the Clarion radio if you still have it please?
Hi g40 mid section exhaust price posted please.
The boost return section, do you have the one way valve that goes from the crank up to the boost return there? I'll also take the breather valve
How much for the door membrane posted please - inner door lining?
Sent from my SM-G920F using Tapatalk
