Can wheel spacers make by our wheels come loose! 😱
Can wheel spacers make your wheels come loose because I was driving down the bypass today and my nsf wheel came loose and 1 bolt was missing!! I used log wheel bolts to so it can't be the bolts??
  • Replies 10
  • Views 1.9k
Did you tighten the wheels up evenly and torque them up? Are the wheel spacers proper hubcentric ones or the cheap halfords multifit ones?
Providing the bolts are torqued properly then I don't see how the spacer could effect that. The only thing I can think of is you either forgot to tighten up the bolts on that wheel (I'm sure we have all done it, I have!) or you tightened them unevenly.
Cheap Halford ones tbh that must be why. Its only on one wheel though. I checked all the wheels before in left the car aswell
I'd put it back on and just torque the wheels up nice and evenly. They don't need to be overly tight. I do mine up to 110Nm, the 9n may be different as you have 5 bolts, but I'd have thought it would be around that.
Ok thanks for the advice coupe. I've took the front ones of for now. I'm gunna put them back on Sunday. I took them of because I've got a lot of driving for but he next two weeks. So Sunday ill put them back on and just keep checking the wheel nuts every day or something.
This is the first time I've used spacers tbh. I've only had them on since Sunday just gone. I've only been driving since November lol 22 and just started driving doh! Lol
The other thing to check is, do the bolts have the correct seat on them, VW wheels need a radius seat, other non VW wheels often need a taper seat, so if you have the incorrect bolts there won't be the required contact area to hold them in even if they are torqued up
Yeah I would check that what nige recommended, I had the same problem and just bought some tapered seat bolts from a bmw.
Also how many turns are you getting on the bolts? Steve said a handy tip the other day of sticking blue tak in the bolt hole of the wheel then popping it out to see what kind of seat is required by the shape
I brought longer bolts I got 40mm ones which are 10mm bigger then my original ones to allow for my 10mm spacers
Are they the same seat type as the ones you replaced?
Yeah exactly the same that's what I don't get man!
