Mk2 Fuel Tank (CARB) WANTED
Hi, I'm after a fuel tank that is free of leaks, for my Coupe S. Let me know if you have one, I'm based in North London.
Gary
  • Replies 8
  • Views 338
New pattern ones can be bought from ECP.
I know, but I'm only after one to get it through an MOT before fitting a G40 tank, hardly worth buying a new one, I may try patching it as a temp fix but thought if anyone had a spare I could just fit that.
You can use a mk2 tank with fuel injection too. Just block off the two bottom pipes and it is just the same. That's what I did and it works just fine.
Ah I didn't know that, so my tank from my G40 would work. I'll have to give that a go.
You can use a Mk.2 tank in a Mk.2F (with the pipes blocked off)but not the other way round if you're still running a carb engine as there are no outlets on the bottom of the 2F tank for the fuel supply and return on earlier cars.
86C - cheers for clearing that up, I've ordered a new Carb tank, gonna fit that for the mot,
Gary.
I've got a 2f 1.0 tank but I'm in North Wales. Can't post it's still got juice in if you still after one
Thank you but I've sourced and fitted a new tank now.
Gary
