polo estate
electric mirrors windows and sunroof not working anyone a idea checked fuses all fine and checked wires in door and motors for windows seem fine
  • Views 509
What year is it?
Depending on the year, the only thing I can see that's common to the roof & windows is the drivers door control unit (motor assy)
51 plate so its motor? passenger side don't work either
OK the sunroof should work regardless of the drivers door window motor, that only comes into use with the "Total closure" feature, there are 2 fuses for the roof, main power #35 25amp & control #7 7.5amp
There is one fuse common to the windows & mirrors #26 5amp the other fuses are #36 & 39 25amp & #10 5amp But if your certain these are all OK my best guess would be the wiring in the flexy tube between the door & body or your unlucky and all the switches have failed
