Indicator stawk problem
Hi there guys, so I've had this issue for a while now and want to figure out how to fix it so when I try indicating left sometime I get it work but most times nothing happens there is nothing showing but when I indicate right it's fine I have checked the lights and they are fine so I'm thinking there's something wrong with the stawk but not sure and not sure how to fix it.
  • Views 484
Take the indicator stalk off and check if the copper contacts are touching each other as they should. Clean it thoroughly with carburettor cleaner or something else that gets it as clean as possible without leaving any residue. Get some dielectric grease off Ebay and lubricate all moving parts. Put it on the contacts as well to improve electrical flow. If it is a switch issue then that ought to sort it out.
