disc thickness?
Hi everyone. Does anybody know what the minimum thickness is on the brake discs of a Polo 1.4 6N2 2001?
Part no.s for........
discs
pads
rear brake shoes?
Discs new 18mm wear limit 16mm
6N0698151C Front pads
6N0615301C Brake Disc (vent) 239X18 4/100
N 90329104 allen key head bolt M8X49 /
N 90329205 allen key head bolt M8X59 /
1H0698520 X 1 set: brake shoes with linings /
The Allen bolts are for the front calipers, they are often a swine to remove and the heads round out !!
If you need part numbers, go to www.vagcat.com you need to register to use the site but it's free :)
Thanks for the above info Nige 8021. The reason I needed them is because my lad who is 19 this month is taking a vehicle mechanics course at college and the Polo I've been asking questions about is a birthday present from me. While he is taking his driving lessons I am getting him to check things on his own car and if a simple fix, let him fix it. That way he'll get more experience and give him some responsibility.
I have registered with vagcat.com and just waiting for a verification email.
Once again, thanks for your help.
Keeping the above dimensions in mind, anyone who wishes to skim their discs in the lath, need to remember that run-out is just as important as minimum thickness.
For this reason, it is better to mount the disc away from the headstock, in order that a cut can be taken from each face of the disc without removing it from the lath. This will almost certainly mean making a dummy hub on which to mount it.
Regards
