TA technix kit Mk1-2f - 80mm
This isn't quite a full kit, so is priced accordingly, but it's ideal if you've got an older kit on already that's getting tired.
Pair 80mm front springs (used very briefly, so do have signs of use)
Pair of front shocks (unused in box, still got the strapping on)
Pair of back springs (used very briefly, so do have signs of use)
Does not include back shocks, clips or platforms.
Price £45 for the lot, would split if you just needed part of it.
Delivery is £8 by UPS for the whole kit, bit less for parts of it.
New back shocks on TA Technix's site - http://www.tatechnix.de/tatechnix/gx/product_info.php/info/p883_ta-technix-sport-shock-absorber-audi-50--vw-derby--polo-i-iii-incl--classic-coupe--rear.html Probably cheaper elsewhere.
post-3073-0-92104000-1455629652_thumb.jp
  • Views 539
What size rear springs 80mm ?
Technix ones are all the same, the height adjustment is on the spring platform with them.
So does that mean lowest setting would be 80 on the rear and highest would be?
Way beyond 80mm to 4x4 height if you use technix shocks.
