dash conversion question (6KV5) to polo 6n)
  • Views 1.4k
so it looks like this dash from Polo 6kv, is the same dimension as the dash from polo 6n2?
Slightly different but you can make it fit. The car is basicly a seat Córdoba which is an Ibiza that originally had the 6n dash board so is very similar.
There are a few threads on here about fitting a 6n2 dash into a 6n. From memory there are some brackets that need to be welded but I'm not sure. There is also the electrics for the speedo etc.
