Polo 9N BETA stereo "SAFE"
Hi everyone, I've just bought an aux in kit for my VW Beta stereo. Whilst fitting it I took out the power connector and now all I see is 'SAFE' on the display. Once it showed me 'safe' then '1000' with the ability to input the code but now all it shows is 'safe' with a 2 in the corner (I presume this is how many attempts I have made to inout the code)
Any help would be very much appreciated
  • Views 535
You need to leave it switched ON with the key in the ignition for around an 1hr Don't attempt to input a code during this time, it should then revert to displaying SAFE then you can put the correct code in :)
I don't want to question your knowledge but.....an hour?! really?!
Afraid so, had the same with the standard HU in mine.
I didn't have the code, and the one the code generator I had gave me was wrong, I solved it by binning it and buying something better :)
ok mate thanks for the help
