Noisy heater motor
Is there any way of servicing a noisy heater motor, mines starting to annoy me and going to have a look at it this weekend
  • Replies 10
  • Views 1k
Take it out spray grese back of hampster 🐹 wheel
Will do me, hopefully the Hamster won't sound like it's being murdered
Take it out spray grese back of hampster [emoji194] wheel
How does it come out?? As a whole unit??
Think u have to take dash out I will check this in Haynes manual later on for u
All done no more hamster in the heater haha
Gr8 sftuff my black breddy has same fault was it easy to do
I wanted to go into work to get some tools this morning but the garage was locked, so I had to use basic tools but I did it haha, it was easy, would of been easier with right tools, took off both pipes for heater matrix, took the clips off at the top unplugged it and just gave it a yank, came out in the end
For reference it's in the scuttle panel
Yeah, slide off the two clips on the top of the casing, unclip the adjuster cable from the tap, pull off the electrical connector block, use long nose pliers to draw back the hose connectors, and then you can withdraw the unit from the engine bay.
It takes literally two minutes to remove the blower unit, complete with heater matrix.
This is absolutely unheard of these days, with thousands of more modern cars scrapped for being written off, just because the heater matrix leaks - and it's too labour intensive to justify repair.
Removed it sprayed it with WD40 and the white grease to keep it lubed
