Lights problem
Hello,
I need your help again
Last saturday I removed my bumper and installed it again, and as some of you know, removing bumper causes an error to appears on dash because you have to remove the fog connector. When installing the bumper the light disappeared
Today starting the car the light appeared again, went outside and everyhting was working OK.
My question is, does a light on the dash appear from times to times after the problem is solved if you don't clear it with vcds?
A scan showed this, as you can see fault frequency is 1 wich means it only happened once? last saturday? Why the light appeared today?
03428 - Activation of Left Adaptive Light
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 126679 km
Time Indication: 0
Date: 2022.14.05
Time: 00:00:02
03429 - Activation of Right Adaptive Light
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 126679 km
Time Indication: 0
Date: 2022.14.05
Time: 00:00:02
Thank you!
Edited by dm222
  • Views 875
Clear the fault and see if it re appears? Thats anoying, if you do it in the future try disconnecting the battery before removing the wiring in the bumper?
Didn't reappeared at least until now.
So lights off?
So lights off?
No, I've been using the lights
