Jump to content
VAG Connectors Pins & Sockets
Recommended Posts
nige8021
Here's some part numbers you might find useful
Audipins.pdf
post-36925-0-36897200-1457366558_thumb.p
1 000979133
1 set: single wires each with 2 contacts, qty. 5 per bag 'order unit 5' / flat contact
1,0 2,8 /
2 000979132
1 set: single wires each with 2 contacts, qty. 5 per bag 'order unit 5' / flat connector with retaining lug
1,0 1,5 /
3 000979134
1,0 2,8 /
(3) 000979129
1,0 2,8 /
4 000979219
2,5 2,8 /
(4) 000979226
2,5 2,8 /
5 000979228
2,5 4,8 /
6 000979136
1,0 4,8 /
(6) 000979307
1 set: single wires each with 2 contacts, qty. 4 per bag 'order unit 4' / flat connector with retaining lug
4,0 4,8 /
7 000979002
1 set: single wires each with 2 contacts, qty. 5 per bag 'order unit 5' / flat connector/sleeve with retaining lug
0,5 0,63 /
8 000979133A
1 set: single wires each with 2 gold plated contacts. qty. 5 per bag 'order unit 5' / flat contact
1,0 2,8 /
9 000979131
1,0 1,5 /
(9) 000979131A
1,0 1,5 /
10 000979225
2,5 2,8 /
11 000979204
2,5 6,3 /
12 000979106
1,0 2,8 /
(12) 000979107
1,0 6,3 /
13 000979143
1 set: single wires each with 2 contacts, qty. 5 per bag 'order unit 5' / angled connector
1,0 4,8 / 1,0
(13) 000979207
2,5 6,3 /
14 000979212
2,5 6,3 /
15 000979135
1 set: single wires each with 2 contacts, qty. 5 per bag 'order unit 5' / flat contact with retaining lug
1,0 4,8 /
16 000979227
2,5 4,8 /
17 000979406
1 set: single wires each with 2 contacts, qty. 3 per bag 'order unit 3' / flat contact
6,0 9,5 /
18 000979306
1 set: single wires each with 2 contacts, qty. 4 per bag 'order unit 4' / flat contact with retaining lug
4,0 4,8 /
19 111971947B
cable shoe
A6,0 /
(19) 111971949B
cable shoe
A6 /
(19) N 0175262
cable shoe
6,0 /
20 8A0972980A
cyl. connector with solder pin
27,5X5X3,5 / 1,0-2,5
21 000979411
6,0 9,5 /
22 000979412
6,0 9,5 /
23 000979413
1 set: single wires each with 2 contacts, qty. 3 per bag 'order unit 3' / cable shoe / (screw connection) / impact profile
6,0 A6,0/M6 left /
24 000979414
6,0 A6,0/M6 right /
25 000979415
6,0 A6,0/M8 /
26 000979003A
1 set: single wires each with 2 gold plated contacts. qty. 5 per bag 'order unit 5' / flat connector/sleeve with retaining lug
0,5 0,63 /
27 000979009
0,5 0,63 /
28 000979010
0,5 0,63 /
(28) 000979010A
0,5 0,63 /
29 000979011
0,5 0,63 /
30 000979012
0,5 0,63 /
31 000979015A
1 set: single wires each with 2 gold plated contacts. qty. 5 per bag 'order unit 5' / flat connector with retaining lug
0,5 0,63 /
32 000979028
0,5 2,9 /
post-36925-0-28018800-1457366689_thumb.p
1 000097014
crimping pliers without insert
2
obtain from service/ workshop equipment
3 111971939A
cable terminal
4 4B0971848
cable holder
6MM /
5 N 10400901
clip
- N 10401001
cable holder
6 111971940A
butt connector, watertight, can be welded
0,5-1,0 red /
(6) 111971939B
blue 1,5-2,5 /
(6) 111971938A
yellow 4.0-6,0 /
7 357972740D
single wiring seal / for cable:
3,9X7,8 1,2-2,0MM light grey /
8 4B0972840
plug
4,0X7,8 white /
9 357972741
single wiring seal / for wire cross section:
5,6X7,8 blue 1,0 /
(9) 357972741A
5,6X7,8 red 1,5 /
(9) 357972741B
5,6X7,8 yellow orange 2,5 /
(9) 357972742C
9,0X7,8 green 4,0 /
10 357972742A
9,0X7,8 white 1,5 /
(10) 357972742B
9,0X7,8 red 2,5 /
11 357972743
9,0X23,5 blue 1,5 /
12 357972842
plug
9,0 black /
(13) 000979980
electric cable in 10m bag
yellow / 0,35QMM
(13) 000979981
yellow / 0,5QMM
(13) 000979982
yellow / 1,0QMM
(13) 000979982B
electric cable in 3m bag -high temperature resis.-
yellow / 1,0QMM
(13) 000979983
yellow / 1,5QMM
(13) 000979984
yellow / 2,5QMM
(13) 000979985
electric cable in 5m bag
yellow / 4,0QMM
(13) 000979986
yellow / 6,0QMM
  • Like 4
Link to post
Share on other sites
  • nige8021
    2
  • Christian6N
    2
  • Dave9n3
    1
Popular Posts
Here's some part numbers you might find useful Audipins.pdf 1 000979133 1 set: single wires each with 2 contacts, qty. 5 per bag 'order unit 5' / flat contact 1,0 2,8 / 2 000979132 1
Lol, these single pins you already can get for ages @VW. They are normal parts in the etka. I got them straight from my local dealer since the beginning of this century. Using them for repairing wir
A source for genuine VAG connectors http://www.ebaystores.co.uk/3-Way-Components/VAG-Connectors-/_i.html?rt=nc&_fsub=7298004011&_sid=59531901&_trksid=p4634.c0.m14.l1581&amp
Christian6N
Using them for repairing wirelooms and even when i build a complete wireloom myself, for aftermarked Stuff or 3rd party equiptment.
and even the sealant rubbers for making the sockets real waterproofed.
These you can collect when you slaught a loom for example.
You can get the most usual pins @VW, some others somewhere else in the internet.
Even the non symetrical pins for older VW's you cannot get longer @VW for a couple of years.
Just on repairwires, but thats not an option for me. So better keep searching the web or the right dealers.
Here is what i mean, the left is the current version, the right the old version which you all know, they need also other tools to release out of the socket.
If you have the right presstool, you can keep your VW in original condition even in such small things like connectorsockets with pins......
Thats what i call OEM++++++++++++++++++++++++++++++++++++ in the smallest details you can have.
Nobody sees it, but you know what you have inside the car, under the carpet, in the dashboard and so on......
cheers
Christian
  • Like 1
Link to post
Christian6N
And you can also, with a bit of searching in the web, find all the original plastictubes with all different distributors in Y and T Form.
For even much more OEM++++++++++++++
cheers
Christian
Link to post
Good work Nige, I used to have to search all over the net for the correct ones/part numbers so I could save paying VW prices
Link to post
  • 2 years later...
Create an account
Register a new account
Sign in
Sign In Now
Announcements
  • Create New...
