Mk2/3 Rear Upper shock mounts
Anyone have one to hand that can let me know the centre hole diameter and also the diameter and thickness of the bush itself please?
I've been in contact with a parts supplier that may be able to supply Polybush mounts and also standard rubber mounts if I give them the size as they stock and supply a huge range of them.
  • Views 656
  • Yea they're geniune Polybush the bright orange ones :P Because of my work I get huuuuge discounts. I already use some mounts I half-inched that are designed for buses lol, just need to know the exact
I have poly rear top mounts on mine made by bonerath, see if you can get hold of another set from germany?
Mine are from a localish supply will cost about £5/6 a pair, if they're cheaper than that let me know :)
Are they made of poly? If they are ill take a set for spares, the bonerath poly mounts are £20-30 if you can find a set for sale😂
Yea they're geniune Polybush the bright orange ones :P Because of my work I get huuuuge discounts. I already use some mounts I half-inched that are designed for buses lol, just need to know the exact size of the genuine mount so I can get some ordered up
Edited by xumado
Anyone ? Would be handy as I could get some before this weekend
