9n GT TDI brake upgrade
I know this has been covered so many times and there is a weath of details on the forum covering this but I have a few questions .
When upgrading to the 312 front brakes , would I be correct in thinking the callipers are the same on the pd130 so all I need is bigger discs and carriers ?
And for the rears I can bolt on TT/vrs/4 motion rear callipers (which are bigger) and carriers to allow 256 disks?
  • Views 2.5k
Nope, you'll need carriers and calipers from TT225, octy VRS, S3 etc etc for the fronts.
Rears bolt straight on IF they're from a front wheel drive model such as LCR or Octavia vrs.
If you have to get them from a 4wd model you'll need to fit a spacer Inbetween the carrier and the hub mount on the car circa 6mm (can be bought from awesome gti, creation Motorsport and many more)
Legend mate cheers !
I'm tempted to see if the LCR brembos will fit under the 16" montrealls
PD130's use the same caliper/carrier..
No worries, unfortunately they won't. They're a 17" wheel minimum and run a 323mm disc. Good upgrade though. A fair few people run Porsche Boxster rears and also boxster fronts. Creation Motorsport sell adapters for these to be run on a 312mm disc and will fit under 16's albeit some need a spacer to clear!
To re say what I did before, you will need calipers and carriers. They aren't the same caliper as the ones used on the mk4 golds where guys just change carriers - I don't believe you can do this on the 9n/9n3 model calipers. I currently have tt225 calipers, carriers and discs on the front of my 9n3 gti
