Garage Clear-out various bits 1.4 16v, VR6
The post:
Was planning on doing a VR6 polo estate but life and plans change. I’m selling all the parts individual or together. The plan was to rebuild one engine from the two.
2x VR6 bottom end 2.8ltr AAA engine codes £100 each
1x was from running car which was knocking was believed to be bottom end on strip down the chain guide was gone. Other was spare and not know. Came from running Ibiza
3x Heads £60 each
3x inlet manifold (early metal ones can polish up nicely) £30 each
1x Gearbox £150
1x Gear linkage £50
1x Engine Loom £60
1x ECU and wiring loom OBD1 (Same as MK2 Golfs) £50
1x internal loom £50
1x 1.4 16v head off auto AUA engine block was knackered head was good £50
1x pair of drive shafts £30
1x pair of 288mm callipers £30
Brand new 1.9tdi Alloy Rad from Direnza (few dents from moving around the garage never fitted  Overall size 720mm x 375mm x 100mm, Core size 650mm x 370mm x 50mm fits other cars please check before buying.
I deal can be made for the lot all you need to make a VR6 £700 an easy conversion for those who own polo variants such as estate and saloon as the mount are in the same place.
All item are located in Birmingham (Marston Green/Sheldon)
Can take photos of individual items if needed.
  • 5 months later...
  • Views 388
£350 takes the all the VR6 stuff
Edited by residentmelon
