polo reliability
Hi guys, I'm looking at getting an old polo. Wanting something basic without electronics everywhere. But I've come across a polo cl "jazz" bready. 91 h plate. 1.3 engine seems to be fuel injected using digijet system ?
Are these reliable ? If not, Can I get a 1300cc polo with a carb ?
Was it only the genesis that came 1300 with 5 speed box?
Sorry for all the questions. Just trying to get as much info in as possible.
  • Replies 9
Very reliable I've got a coupe and breddy both 1.0l single point injection and I've towed all kinds with them, but putting a 1.3 with twin choke carbs and points in dizzy
I have both a carb'd 1.3 and a 1.3 GT. Cant fault the GT now the work that was required has been done. Runs perfect all day everyday, whatever the weather and whether I'm poodling into town or doing 400 mile trips filled to roof with stuff and the ass on the floor with the weight. Best, most reliable car I've owned.
The carb'd one also the same really, even on the original pierburg. I do slag mine off as I think pierburgs are rubbish; but again, sun or snow it's never failed me.
BUT it still depends on who's owned the car and if they've looked after it.
And in response to your gearbox question, no other specs did come with a 5 speed box but appears as somewhat of an option where some cars have it and others don't.
Digijet? Correct me if I'm wrong but isn't that the multipoint injection instead of the more common single point injection?
Anyway assuming the car has been well looked after then it should be just as reliable if not more so than a modern car I'd say. If it is the engine I'm thinking of then some parts are a bit odd on it but most are easily available either second hand or new.
You can get a 1.3 with a carb but these will be the older mk2 Polos.
Cheers guys. Was just thinking keep it simple. Sick of engine warning lights and reading fault codes.
May well have a look at this one then. Need a car for work now. Fancied something different.
There a light blue mk2f or red one cheap on ebay
My 1.3 AAV single point injection was brilliant. Couldn't fault it apart from the odd oil leaks occurring and what not. I did put about 4k on it though in around 4 months. The fuelling and electrics never went wrong. Had a leak at an oil pressure switch and replaced it for a couple quid. Parts are dead cheap.
Also my fan switch went once. Word of advice I would say to buy febi, topran or genuine parts wherever possible. Eurocarparts have sent me a couple dud things
Cheers, anything in particular I should look out for when viewing one? Common rust spots or whatever.
Thanks again.
The 90-94 cars were normally Single-Point injection, apart from the GT's and G40's. Digijet is the multipoint injection one (engine code NZ). The engines themselves are generally reliabile. The digijet injection is a bit odd, but by no means as much of a pain in the arse as a modern car. If you're methodical and can use a multimeter, you can pretty much find any electrical fault on them.
It's not a complex system. Electrics-wise, all there is is a breakerless distributor-based ignition system that runs separate to the ECU and fuelling.
There's not really much to the fuelling it's controlled by:
Lambda
(Blue) coolant sensor - basically, consider this a service part
Airflow meter
ECU
The NZ isn't particularly common in the UK, but parts availability should be fine and mostly cheap. I've not had enough experience of them specifically to say anything on reliability, but I've no reason to think there's any real problem with them.
5 speeds were an optional extra across the range on the 90-94 cars.
Rust, the main bad spots are the battery tray and the fuel filler neck/back of drivers sill. The chassis leg to bulkhead it worth a good looking at. Some silver and white cars that can really get the rust bad everywhere due to thin paint.
If it's round Peterborough and you want a second pair of eyes when you go for a look, I'm only in Spalding so could give it a look.
Cheers man, appreciate the offer. Finding a nice car is pretty hard. Nothing local anyway.
