one sided wheel alignment help**
hi all,
just had new suspension fitted so need to get wheel alignment done.
I use to do these back in the day but have long forgotten how to do it...
I have a polo 1993 mk2f - as you know they only have one side adjuster.
I wanted to ask - how do I do the wheel alignment/tracking on this?
do I set one side to zero and then do the other by removing the steering wheel??
any help/links on how to do it will be appreciated :)
Thank you.
  • Views 669
  • kwijibo_coupe
    kwijibo_coupe
    Pretty much got it in one. Set the drivers side with the wheel and lock it in place. Set the passenger side with the adjustment on the steering arm. Remove steering wheel and centre it.
Cheers mate - will give it a try!
