Alternator belt
Hello everyone
I have a 2009 Polo. I have never changed the alternator belt so far. Currently I have around 90,000 km on it.
How can I know it is time to change the belt?
Thank you for your answers.
Cameron
  • Views 942
  • steveo3002
    steveo3002
    look at it on the side with the ribs on , is there any sign that its cracking or failing? not that expensive so maybe just replace it anyway
Thank you I will have a look
It costs around 400 pounds in France
you could maybe do it yourself if you have a bit of mechanic experience , the part wont cost much maybe 25e
There's no way an alternator belt should cost £400 even with a main dealer fitting it!! they cost £15~20 & 1/2 man/hr to fit. Are you sure that wasn't the price for the cambelt ??
I am very sorry for the misunderstanding. I just doble checked and yes the price is for the cambelt. So I wanted to ask about the cambelt not alternator belt. The reason why I ask is because for some VW cars the cambelt needs to be changed in every 5 years but for others it is 10 years as far as I know. I don't know if I need to change or not. Even the mechanic near my house doesn't know.
Ah! That makes sense of the price :)
What engine do you have ? if it's a 1.4L petrol there isn't a specified time limit/distance for replacement only to inspect it @ 90,000km and then every 30,000km afterwards, the other engines do have time/distance recommendations
Here's the service tables for the 9N1 & 9N3 9N Service tables.doc it lists the time/distance requirements for inspections/replacements
