Polo 6n MkIII - Lost keys !
Hi,
I can get a set of locks and ignition + keys from breaker.
I believe i will i need the same immobiliser from the breakers car , but do i also need the ecu ? or will just a matched immobiliser do the job ?
  • Views 1.5k
don't buy a lock set. I take it you got 1 key for all locks. If so remove drivers door handle and give it to a mobile key cutter to make you a key, then once he has made a key get them to programme it to existing ecu...
