Carburettor flange problem?
Hi all. I have got a problem with my carburettor flanges keep splitting. The last 2 I have got from gsf have split. Can anyone recommend where to get one from that will last more than 5 minutes?
  • Replies 10
  • Views 1.6k
  • Interesting thread. My last five have all split too. I get about a year out of one. The latest one seems solid, its an italian brand called 'birth flange'. I kid you not.
Not sure if this is the right one. Can anyone confirm? It looks a different shape to the ones I got from gsf?
http://m.gsfcarparts.com/181vg0400
Edited by GUESTY
Gotta love a bit of birth flange ;)
Where did you buy it from btw ?
Yes where did you buy it?
Do you have a Weber TLA or a Solex Pic or a Pierburg 1B3 fitted?
Last time you asked you had a SolexPIC carb.
A Weber TLA would need a different flange which I think is the one that kwijibo shows.
http://www.clubpolo.co.uk/forum/index.php?showtopic=344149&p=2680893​
I reckon Febi 02365 (052129765A) for early Solex PIC - with two mount holes on perpendicular line in outer bolt pattern rectangle,
and Febi 02364 (030129765C) for later Weber TLA and Pierburg 1B3 - with two mount holes on diagonal line to outer rectangle bolt holes.
o o
o o
versus
o o
o o
Edited by dvderlm
It's the 030129765c. Who sells the best quality one I can get that will last?
Edited by GUESTY
The Birth Flange was for a Pierburg 2e3 and came from an ebay seller.Can't spot one on there at the mo though.
Thanks dvderlm I'm going to order it today.
