Polo Breadvan project for my daughter and I
Will deffo be keeping an eye on this thread. Good to see another polo been kept original. Good work matey. P.S will be painting the black strips on them wheeltrims soon. Wish me luck!
Edited by TommoPolo15
  • Replies 85
  • Views 8.3k
  • kwijibo_coupe
    kwijibo_coupe
    Refreshing to see a clean car being tidied up nicely instead of slammed on 9j wide wheels with cut up arches and a bike carb conversion. Keep up the good work :)
  • This is a nice thread - here we have a genuine breadvan which has fallen into the usual poverish but unabusive ownership for a number of years, fought it's way through on build quality and charm, and
  • Loads of photos! My kind of build thread The navy paint and light grey interior go really well together.
Hello mate, was wondering were you were up to with the wheel trims, plenty of luck and a steady hand is whats needed.
Thanks for your comments
Worked on the O/S front wheelarch this weekend. Wire brushed and sanded the surface rust and painted the inners with blue smooth hammerite and then brushed on seam sealer in the obvious rust / rain traps and also prepared the inside of the front wings and brushed on seam sealer again to prevent rust / rain traps.
Next job is to drill indicator holes in the front wings and paint them in the body colour. Replace the discs and pads then bolt on the wings then on to the N/S
Just some advice try stay away from hammerite paint as its not that good. If you can use epoxy paint if funds allow . Keep up the good work ..
Thanks for the tip. I might try epoxy on top coat in dark blue.
Edited by volksfan1
I have used epoxy 121 on my chassis on my 1970 beetle its good stuff and have good results with it , not cheap but well worth the extra for protecting metal..
I'm just thinking about the top colour. I also have paintable underseal to goon. I want it to out last me [emoji3]
Don't we all :D
Ha Ha Ha,
Guess I'm stating the obvious there. I just need to learn to weld next
So today i put a second coat of paint on the breadvan after seam sealing potential rust trap areas so it should be a while before it needs looking at again.
O/S inner wing
Sills
Front panel
To do list:
N/S wing removal;
N/S inner wing assessment and refurb;
Remove grill and headlight and refurb panel;
Drill indicator holes in new wings;
Primer wings and possibly paint top coat
colour;
Refit wings with new aerial in N/S wing;
Paint front panel in top coat colour;
Refit front bumper;
Replace driver's door, following replacement being painted in top coat colour after removing the few minor dents that it has in it;
Refurb engine;
Refurb cooling system;
New exhaust and finally
New MOT
I will replace all brakes one front prior to fitting new wings and then refurb rear drums prior to MOT.
I have already stockpiled all of the replacement parts
Edited by volksfan1
If your using aerosol paint, I found out the hard way that it doesn't like to stick to hammerite. Not sure if primer will help but might be worth a test on something just incase.
Thanks for the tip, the second coat i have put on is not hammerite.
And the N/S front inner wing, again only surface rust and no welding required. I'm very happy with the condition of my car.
Front grill removed and again only surface rust, a relief and bonus. Think we have been lucky with this Polo
Edited by volksfan1
Final coat on N/S inner wing
A good couple of days work and a large smile on my face too
Edited by volksfan1
Front panel and behind the headlights done too, its coming along nicely too:
Playing catch up here, moving along quickly :) nice work and it looks pretty clean for an oldie
Sent from my SM-G925F using Tapatalk
Yes it a nice car, surface rust only, so far
  • 3 months later...
AND SO THE REBUILD STARTS.
Its been a while since i have done anything to my daughters breadvan but today i began the rebuild. Put the two front wings into primer.
Will hopefully put them back on over next fortnight, rebuild will slow at first as im recovering from my knee operation but we will get there in the end
Keep up the good work :D
Front wings go on.
O/S first - not a bad fit for a pattern part
Then the N/S - not a bad fit too but needs a bit of work as it stick out slightly proud of the A post but im just going to slacken off the bolts and push the wing in until its flush them tighten the bolts whilst the pressure is against the wings edge.
On ‎31‎/‎03‎/‎2016 at 20:39, volksfan1 said:
And this is my daily, but there's also a thread on here about it
I hope the 16v bumpers come up a treat after they have been refurbished. Checked out your mk2 breadban and it looks fab. Reminds me of my first polo.... A mk2 polo S in jade green colour. Post a picture of the 6n with bumpers fitted.?
I will do mate. I have just put a picture up of them on club polo, have a look
Its on the the my new (to me) daily driver
The time has come to consider selling the breadvan.
There are lots of new parts,
Service parts,
Brakes front and rear,
Spare drivers door
Bumper
Just havent had time to recommission it and now my daughter wants a newer car so i think i may have to sell up.
I have been given a price of £500 in my hand for the registration number so i may sell that and then either sell the car as it is with all of the parts for a new owner to either break or re-register and recommission as it really is a good car and i refuse to break it myself.
Im still in two minds, any thoughts or interest.
I havent put a price as im still undecided but was thinking of £300 all in - less the registration
Are you able to sell the reg if it is original to the car?
Depending on your final price and what it needs I may be interested, fancy another mk2.
