wireless key central locking help!
I have central locking ib my 6n2 with the key how do i go about fitting a wirless key off ebay?
Regards jordan!
  • Views 698
  • You need to connect it to the wiring for the pump unit in the boot, depending on what you are buying will depend on how to connect it, if you buy an "R-Click" unit, you can buy a plug n play adapter l
You need to connect it to the wiring for the pump unit in the boot, depending on what you are buying will depend on how to connect it, if you buy an "R-Click" unit, you can buy a plug n play adapter loom, that makes it so simple, just remove the connector on the pump, connect the adapter loom to that connector and plug the other end onto the pump :)
I was thinking this one
http://m.ebay.co.uk/itm/VW-Univers-Car-Auto-Central-Keyless-Entry-Lock-Locking-Remote-Control-System-Kit-/322016836248?nav=SEARCH
So what els would i need? Sorry i have no idea!!
Without seeing the connections diagram for that item, I can't tell you how to connect it to your car, but you will need some splices/crimp connectors
Oh 😧 any help on witch to use? ☺?? As i have no idea and can not find a walk through off one
For simplicity on the install get the one from RClick it's just plug n play :)
As nige says I got a "r-click" one for my old 6n2 and it was plug and play bar the indicator wiring but that was simple
