How reliable is your Polo 6R? (Mk8)
Mine has been a nightmare with repairs, for a 5 year old car with 48k on the clock....Is it just me? How reliable would you say your polos are?
In the last year alone I've needed to replace (and not all of these are done yet)
+ 4 tyres - Understandable
+ Front & rear discs & pads
+ Clutch
+ Drop links
Oh and the mechanic thinks the timing chain might doing at some point...
  • Views 772
  • In Guernsey the maximum speed limit is 35mph with most roads at 25mph, lots of stop starting so clutches are common
I have a 6R TDI 42k and it's been golden apart from a couple sensors when I first got it, it was firing a couple warning lights at me.
All your list is just wear and tear stuff though. Driving style will determine the deterioration rate of those components. You could get a hell of a lot worse at that mileage with some of the polos rivals.
The 6R has very good reviews for reliability from consumers. Only DSG models seem to have common failure ( something to do with the clutch or gearbox but can't remember)
Mine needs discs and pads now, I drive quick at night on the way to work and have probably accelerated wear now. Discs are just starting to lip. A lambda sensor went and some sensor just before I had it too. That's all mine has had done all its life I believe other than servicing by vw.
Mechanic could be pulling your leg trying to get extra money, have a look at the life expectancy on the timing chain and how old yours is vs the mileage etc
