Gt engine and gearbox
I'm carrying out a g40 conversion on my gt and will be selling my gt set up.
Spec includes:
Engine has done 91k
Port and polished head, done 25k from new
Chipped ecu
Air filter induction kit
G40 injectors
Gearbox is a fully conditioned box that's done 35k
I've really looked after this engine with an oil change every 5k so you'll find the oil is clear without any particles at the bottom of the sump.
I will also be selling the front brake set up to go with it.
Looking for £350 all in, collect from Manchester.
If you'd like to hear how it runs I've got a video I can send you.
Bad bits:
It won't come with the Portland polished inlet as I'm putting it on the G40, but will include the g40 inlet with it.
It will be coming out of my polo on Thursday and needs to be gone within 2 weeks due to space.post-920267-0-46611000-1460101717_thumb.
Edited by NickBraddock
  • Replies 16
  • Views 790
Willing to split the engine and gearbox, subject to offer
Hi mate how much for the gt cam?
Hi, I'm not splitting it up by taking it apart sorry
What front brake setup have you got?
Hi have u got all ancillaries for conversion loom ecu and all bits needed for conversion
The front brakes are the standard gt set up.
It'll come with all parts other than the lighting loom as I'm having to use mine.
Everything as mentioned at the top of the post including a chipped ecu, engine loom (lighting loom i'm having to use as the g40 lighting loom is damaged), g40 inlet manifold and 200cc g40 injectors, induction kit and ported and polished head, exhaust manifold and cat pipe section, gt gearbox including mount and driveshafts.
Pm.d you bud
Still available
Nick you coming down on price yet?
Do you have the lift pump out of the tank?
Used that for my g40 conversion buddy
Still for sale, I won't go at lower than £300 because of how well looked after it has been and the work done
How much for the gearbox , delivered in mainland uk if poss ?  Cheers. Colin.
sorry I can't split it as I would like to sell it as one lot
Sold
