Mk2 Door change
I'd assume this is a pretty simple question to answer but I just haven't had the time to look at the car yet.
I've have an drivers door skin which has the winder mech and interior door release mech and lock mech on the end.
How long does it take to change the glass from my current door as well as the door handle with the exterior lock?
And whats the method of removing and refitting the glass or any tips for doing it?
Julian
  • Views 662
  • Door card off. Wind the window down. Undo the quarterlight (screw at the top, bolt in the door) Slide the quarterlight out . Undo the clamp that holds the glass into the window reg along the botto
Door card off.
Undo the clamp that holds the glass into the window reg along the bottom of the glass (2 bolts)
Lift the glass out (I tend to rock it forwards.
Reassembly is the reverse of disassembly, but with different swearwords, less hammers and three leftover screws.
Door card off.
Aha, Legend :friends: New doors will be fitted tomorrow then
