Tuner wheel bolts
Basically I've been searching everywhere and can't find anyone who sells the tuner/internal splined style wheel bolts with a radius seat for vw wheels. Every one I've found are tapered seats, so here's my question. ... does anyone know if these type wheel bolts exist in m12 x 1.5 x 45mm? Of so where can I find them?
Sent from my GT-I9505 using Tapatalk
  • PHIL SWARBRICK
    PHIL SWARBRICK
    I looked for some time and never found any bolts that are radiused to suit VWs unless you look for 16 anti theft bolts. Also there is never any guarantee that the chroming or other plating will last.
  • wizardmanjm
    wizardmanjm
    I got some from eBay, can't remember the seller but I think I bought two sets by accident so I'll have a look Sent from my SM-G925F using Tapatalk Sorry I'm thinking radius is chamfered, I have ch
I looked for some time and never found any bolts that are radiused to suit VWs unless you look for 16 anti theft bolts. Also there is never any guarantee that the chroming or other plating will last. I bought another set of stock bolts and got them chromed properly. (not just chrome on steel) to make sure they never rust. It cost £77 but they look excellent and I know they won't rust especially when I live beside the sea. To make the plating more effective, I had the end of each bolt machined so the depth of the recess is now about 3mm along with a champher so part of the plating process will get into that recess which again will protect against corrosion. I hope this helps and is a possible alternative for you.
Regards
Phil
I thought I had saved a seller on ebay that listed M12 radius turner bolts but It's gone ??
Sorry I'm thinking radius is chamfered, I have chamfered so ignore me!
Thanks for the input guys. I've gone for standard bolts now. Gonna look into nice caps for them maybe shotgun shells, heard they look good and fit 17mm hex too.
