Bleeding mk2f gt brakes on alxe stands Help
Am I correct in saying the rear wheels have to be on the ground for bleeding brakes on my mk2f gt ,This will prove a problem as its to low for me to get under car.
So I will have to bleed brakes on axle stands.. Where do I stand with the bais valve as it wont bleed correctly with having no load on the wheels ?
  • Views 545
Put the axle stands under the bottom of the shocks, that way it will set the load limit valve to a mid position that'll be OK to bleed :)
Great stuff many thanks :D
