Mk2f slam panel
My gt has been in a bit of a accident, I'm planning on changing the slam panel/front panel, can anyone explain how to remove it? Is it welded or bolted?
  • Views 858
Hi mate,
exact thing happened to me and well I'm happy to say that my cars back to the way it was ;). It is welded on to the body of the car so removal of one from a donor is tricky. I found a german copy manufacturer on eBay and got a replacement. it was pretty similar but, it doesn't feel anything like the original. As expected from a copy its lighter, thinner cheaper as a whole. When it cam down to fitting the headlights eat. everything came along ok expect my grill which is a de badged one. It didn't fit exactly as the retaining holes where placed a little lower than where my grills clips aligned. So with a bit of fiddling i got it in not 100% and my mechanic put in to discreet screws which aren't noticeable. but it set me back £600 in costs to repair back to the way I had it however, I had the wings,bonnet and slam panel re sprayed as well.
