Making your own Braided Lines
Been asked this a few times in regards to the full braided setup on my old Polo, there were no solid metal lines left in my build and the car needed the original lines replaced to pass an MOT, now my MOT tester was very stringent that if i was to follow this route that the system could have no extra joints over the standard setup.
I was fitting a 4 port 22mm Master Cylinder so every wheel had its own feed (acting as a split circuit in the event of a line or caliper failure, so there would still be brakes), I had already replaced the rubber pipes in the past so used the braided lines i already had for those sections on the mk2F.
All the parts for my build came from West Wales Rally Spares, (Parts for MK2F (nonG40/GT) list to follow)
I have in the past made my own replacement solid lines but decided on a different route this is the guide that I followed for making my lines....
Making Braided Steel Oil and Brake Lines
by Fred Eaton
Summary:
This article covers the proper way to build your own braided stainless steel oil and brake lines using reusable fittings. In this article I will build a one-piece front brake line for a Norton Commando race bike, however, the procedure would apply to any other braided line.
Procedure:
First: measure the existing line, or in this case, the length from the master cylinder to the caliper. I put the bike on a stand so the front wheel is fully extended. Then I like to use a piece of ¼" hose or an old cable to string from the master cylinder to the caliper (string would work as well but you will need to allow enough extra for the braided line to bend into the fittings). Mark the hose at the fitting where the hose will meet with the fitting on the master cylinder, then mark the hose at the caliper fitting. Remove the hose and measure the overall length.
The following pictures are using a different fitting than is described in this article, but the install is the same for all our -3 fittings.
b_line_a.jpgMarking the hose where to cut.
Second: cut the braided line. For this line, I used a 90 degree fitting at the master cylinder and a 45 degree fitting at the caliper. The 90 degree fitting extends the length of my line by 1 ½" and the 45 degree fitting by 1 ¼". You can subtract the amount the fittings extend the line from your first measurement (or in this case I only subtracted 1"). You can always cut the line shorter so I like to err on the long side. You can cut the braided line with a Dremel cut-off wheel, a fine tooth hacksaw, or anything that will cut and not fray the braid. To prevent fraying, put electrical tape around where you plan to cut. Our new brake line (part # 54-800101, $8.75, per foot as of 09/26/07) comes covered with a clear plastic protective cover, so you do not need to use electrical tape to keep the ends from fraying. After you cut the brake line with the protective cover you need to remove around 1" of the covering from the ends. I remove the covering with a sharp knife by first cutting the cover down to the braid, 1" from the end, all around the braid, then cut from the end in a helix cut down to the first cut. You should be able to start peeling the cover off at the end and down to the first cut.
b_line_b.jpgCutting the hose with a Hacksaw.
b_line_c.jpgRemoving the clear covering from the end.
Third: Thread the threaded compression nuts on the line, making sure the threaded end faces toward the end of the line.
b_line_d.jpgThreading the compression fitting on the end of the hose.
Fourth: Take a small screwdriver and gently spread the braid out so about 1/8" of the hose inside the braid is separated from the braid. The fittings I use have a compression ring that is ¼" long, so that is why I spread 1/8". Then feed the compression ring over the inner hose with the tapered part going over the hose. Just get the ring started, then push the ring home by placing the ring against a piece of wood and push on the line. This keeps the braid from inserting itself into your fingers. Look in the end of the ring and make sure the hose is completely seated. I like to take a punch the same diameter as the ID of the hose and push it through the hose to dislodge any frayed part of the hose and make sure the fitting will feed into the hose.
b_line_e.jpgSpreading the braid.
b_line_f.jpgCompression ring installed.
b_line_g.jpgCleaning up the ID.
Fifth: Pull the compression nut over the compression ring and thread a couple of the threads on to the fitting by hand to get it started. Tighten the nut to compress the compression ring. The nut normally comes very close to touching the fitting when correctly tightened. A small gap is acceptable. Tighten the nut on to the fitting by placing the proper box wrench for the fitting hex head into a vise, then insert the fitting into the box wrench, then tighten the compression nut with another wrench. Please note, the fittings are reusable, but the compression rings need to be replaced if you are placing the fitting on a new section of line.
b_line_h.jpgInserting the fitting.
b_line_i.jpgStarting the nut on the fitting.
Last: Spray PJ1 Contact Cleaner through the hose to clean any contamination that may be there from the cutting and assembling process.
I personally found it better to mark the cut and then wrap a piece of masking/electrical/duct tape around the braid to keep the braid form snagging/pulling if the hacksaw was a bit blunt.
22mm Master Cylinder:
From Engine bay and to rear:
Axel to Rear Cylinder:
Edited by Cymro
Will be writing this as i go along.
  • Views 2.8k
Good guide, saved this for later, thanks :)
Am hoping to get more information on this written up this week. Sorry for being lapse.
Sent from my LG-H850 using Tapatalk
