Complete MK2F 1.3 Engine, gearbox, shafts and all associated parts
Hello Chaps.
I recently got hold of a MK2F bread van which I have a lot of plans for, because of such I have a lot of surplus parts left over which have been removed for replacement. Due to having sourced a 16v motor I am hoping to re-coupe a little bit of the cost.
I have no knowledge at all about these engines so please bare with me.
The V5 states engine code NK, 1272cc, SPi, 5 speed box. Mileage from what I remember is around about 85k but I will have to confirm this.
In the sale I will be including the following.
Engine with all ancillaries
every ignition related item
loom and ECU
Driveshafts
Gearbox
I will also include any other parts required for instillation
170BFE46-EB76-40CC-8BF7-58D33F902CC2_zps
As you can see the engine is still in the car so can be seen running, can be driven and assessed by any potential buyer. I am happy to pull the engine, or you can use my engine crane and pull it out yourself.
Like I say, I have almost no experience with these engines or their value, the only comparable item on ebay (by comparable I mean the same engine size and year) is hevily modified for a rally car and is therefore not comparable. Because of this I am a but stumped.
£250 for me to remove it
£200 if you come and remove it
These prices are open to negotiation, as like I say I don't know its worth.
Delivery is possible at cost, usually £60 anywhere in uk mainland, some areas of scottland seem to fall into £75.
Based in Kent.
  • Views 629
can i buy parts off it not the hole thing ?
Depends a lot on what you wanted really.
What at is it you was after?
I'd be interested in the gearbox if you seperate I'm in essex and would pay £80 cash for it
