Mk2f 1.3 SPI Long Commute
Has anyone got any experience of using a Mk2f for a long commute (65 mile round trip). The journey will mainly be 50mph single carriageway or 70mph dual, with a bit of country lanes and the start and town driving at the end.
I've currently got a 4spd Mk2 polo 1272cc with a carb and I want to take it off the road as a project, I've done the journey a few times in it and it's actually very comfortable and a 5spd box would make it even better, therefore I think an SPI 5spd would actually be OK.
Any idea what MPG I could expect?
Thanks.
  • Views 828
my carb 5 speed gets a solid 45mpg  so should see that or more with inj
its not a problem as long as the car is well maintained and you keep on top of maintenance
It will depend slightly on what gearbox you get. A GT gearbox (AHD or CEH) has shorter ratios and they scream at like 4000rpm at 70mph, whereas an 8P or CEG from a 1.3SPI are closer to 3000rpm at 70mph. There is also the various choice of other 5 speed gearboxes from the likes of a 6n that will fit too.
However if you convert to injection and everything is working fine then I see no reason why you shouldn't see at least 40mpg. Could maybe even push that to 50mpg if you plan well ahead while driving.
I've been to Stanford hall from Liverpool wich was 280 miles all in in an managed 45mpg in my mk2f coupe spi 4 speed and was reaching 70/80 mph
All sounds good, I've just done about 270 miles in my mk2 polo and got 36mpg from it. The journeys being quite typical for me.
I'm quite confident that I could achieve at least 40 mpg from a 1.3spi with a CEG gearbox, got my eye on one at the moment.
Probably would also help if I left the 200 piece halfords socket set, other tools and spare battery at home, they must weigh as much as a passenger!
