Mk2 f aau 1043 fuel pump fuse
Can anyone tell me where the fuse for the fuel pumps is?
mr haynes says above fuse box but i cant see it
 believe I've checked relay out
 pumps work when directly connected
 earths check out  i think having done continuity with my meter
but think no poer on live unless its bypassed hence
no fuel to injector though it is present in the in pipe ( haven't done the squirt test)
might the injector be blocked ( fuel filter was filthy)
Help needed and appreciated
  • Views 1.3k
There should be a blade fuse just above the fuse box. Usually a yellow one.
Ah thank you
it is missing ffs
