Polo 9n3 Jack axel stand location
    • Hi,
      where are others jacking up there Polos from?
      jacking points are not clear, are the points I'm using fine?
      jack on sill & axel stand on rubber grommet,
      thanks,
Edited by Dean9n
  • Views 6k
Front I tend to jack on the subframe and stand on the chassis rails, but I don't have my under tray on.
Back I jack on the spring seat and stand on the rear beam.
If the wheels can stay on, I generally just use a big pair of ramps.
Cheers, good to know other jacking spaces.
out of interest, would you say the places I have used would be safe anyhow?
cheers
I wouldnt personally use the locations in the first two pictures. Third is chassis rail, so ought to be okay.
