help lower my mk2
hi I'm going to lower my mk2 and been looking through ebay and saw these 2. i was wondering which is the bes ones to go for and if i buy the coilovers will i have to modify anything to get them to fit or can i just drop them straight in i know coilovers are more expensive but are they worth the extra money?
cheers
Shocks and springs
http://www.ebay.co.uk/itm/VW-POLO-MK1-MK2-MK3-86-86C-LOWERING-SPRINGS-SHOCK-SUSPENSION-KIT-80-80-BEARINGS/130874303293?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D36381%26meid%3Dcafcde6bf33c4a8e97deb281d6faac78%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D201528755644
Coilovers
http://www.ebay.co.uk/itm/COILOVER-VW-POLO-86C-MK1-MK2-MK3-DERBY-ADJUSTABLE-SUSPENSION-COILOVERS-/201528755644?hash=item2eec0cc5bc:g:3kUAAOSwDuJWzv5N
  • Views 621
I have asked roughly the same thing recently. I have been told if you get coilovers you need new lowering arb bushings that are £55, new bearings and hubs (that i found for £50 on ebay but you need to get the bearings pressed). so other than that coilovers drop straight in, but consider that little added expense.
Cheers any chance you could find a link to those i was thinking of going down 80/80 but i can find any pics of polos that are lowered at that height so didnt want to spend money and it look the same height
Thanks alot so if i get and fit these the polo coilovers should just go on. I cant decide which would be the best option as just the coilovers are £350
