Mk2f gt master cylinder
Am after new master cylinder for my 91 mk2f gt , ecp are out of stock so links and advice on buying a new one please ?
  • Replies 13
Can anyone help please ?
4 minutes ago, kwijibo_coupe said:
Here. http://www.ebay.co.uk/itm/MASTER-CYLINDER-For-BRAKES-VW-POLO-Coupe-86C-80-1-3-G40-113BHP-Top-German-Qua-/191214328121?hash=item2c85431939:g:EAQAAOSw-ndTnEMd
Says it is just for a Polo G40 but they are interchangeable. I have a feeling this is the 20mm 4 port version. If you just want to replace this and nothing else then just simply lock off the port you don't need.
Good man thank you Kwijibo and not a bad price ..
I ordered the above and a day later I had and email from them telling me it is not the correct one for my 91 gt coupe and was told please sent it back and I will get a full refund .. So any idea why this has happened ? I emailed them and was told incorrect part..
Have they sent it out? If so when you get it take a couple pictures and post them up. I'll tell you if it will fit.
If it is the one I think it is then it will fit just fine. I run that one on my GT.
No not got it yet but it on its way , when I get it I shall post photos . Thanks Kwijibo
So what do you think ?
Edited by 1vw2many
It looks exactly the same as the one I use and a search online suggests the same.
I'd just block off the port you don't need and try it. Then if you ever renew the brake lines then you have the option to convert to 4 individual lines like I did.
Well after the email to the seller they told me it is for left hand drive and the bore is 1mm smaller than the rhd..
Yeah mine is from a LHD and the bore is 1mm bigger (20mm instead of 19mm)
It will fit, trust me :)
Ok am good with that a shall keep it then just search for a plug for one of the ports ...
The guys on eBay will just be covering their backs by saying it is the wrong one, which technically it is. But it fits and in my eyes is an upgrade, which for the price isn't bad.
I think an M10x1 bleed nipple will work as a plug, just in case you have a spare kicking about.
Yes I see your point as for the m10x1 bleed I do have some spare ones ..:smile:
