MK2F breadvan breaking.
All parts avalible, 1.3 5spd.
Panels are are all straight but have poor paint and will need repairs.
All light units present
interior in fair condition
located in the south east but all parts avalible.
Please PM for any parts.
  • Replies 18
  • Views 2.1k
is this a Van or just a bready?
Hi Tomm,
I'm after a few parts for my polo - let me know if you have these:
Bonnet
Small section of bodywork at the base of the drivers side B pillar (I can remove the window  and cut this piece out with my angle grinder)
Rear outer sill sections both sides - I can cut these bits out also
Fuel tank (only if already removed)
Pieberg carb
Cheers.
It's not a comercial van, but the breadvan, 5 windows and rear seats.
All of of those parts are avalible, hadn't thought of chopping the shell up for parts but can be done.
I am unsure on the carb, my breaker is an SPI so don't think I will be able to supply that
unfortunately.
HI Tomm,
Can you PM me with your phone number - I can then arrange to remove the necessary parts.
The main thing I need are a couple of sections of bodywork around the B Pillar / Rear window (Inside & outside). Our breadvan is rotten around that area and I'm thinking the easiest way to sort it is to weld in the sections from another car.
I'll only bother to take the fuel tank if it's already removed (I removed our fuel tank and it was a right game - same with the rear sill sections as I won't be able to grind these off with the fuel tank in place).
If the windscreen is Ok I'll take that & also there may be some bits of trim etc. that we need for ours.
I won't need the bonnet - Ours is an 86C (E Reg) and I think the bonnet is slightly different on the older model.
Cheers,
Al.
Edited by B@stard
Hi tom do you have the bumper covers front and back and the fixings - thanks Karl
Pm'ed you back Karl.
I will get some photos and drop you a PM  over the next few days of that's ok Al? Check what I have is what you want.
Regards.
Edited by Tomm
Hi Tom,
I'm after a couple of small bit posted please.
The chrome insert to the passengers door handle and the black plastic trim that sits between the wing mirror and the door. You can see it missing in the photo below.
BAUf1UC.jpg?1
Cheers.
I'm after drivers wing mirror and all the linkage to the adjuster knob. Posted.
also driver door international pillar rubber bead that holds the window in its track
Edited by Jameselsworth
rear shelf unmoleted and the little arm thing to close wind deflector on passenger side
Hi could you find out what code the gearbox is please? It's located at the top on the lip closest to where you connect it to the engine, there is a plastic plug in front of where the code is
Hi,
do you you still have the wing mirrors, dashboard and vertical rubber seals for the drivers and passengers door windows?
cheers
I've just acquired a 1994 MK2F polo which i'm getting ready for my partner to use as a 1st car/learner. I've done most of the mechanical work on it but need the following bits if anyone has them..can collect from most areas with a bit of notice.
Door Mirrors
Fuel Pumps (both have a terrible whine)
Full interior (seats, door cards etc as car was used as a work van and they are knackered)
Rear Lights
Carpets
Anything else you have as these cars are getting difficult to find parts for.
 Many thanks!
Alright bud.
im after the door water/wind seal retaining caps. The leading edge of the door casing has like a foot long rubber seal heals in place by 4 caps. I'm after all 8 if you have them. Poster to Lincoln. Please :)
james.
Do you have any of the black plastic centre caps?
Hi, have you still got the tailgate and therear bumper?
Hi, do you have a 5 speed gearbox for sale?
Looking for a tailgate and strut do you have these available?
