Air conditioner blower turns on and off by its own
Hello everyone,
I have a 2006 9N3 1.4petrol with climatronic
When i turn my AC on it blows air for like a minute then it stops for another minute then it starts again and so on.
also on low speeds it nearly doesnt blow any air, and I ran a diagnostic test and it gave a 4F9 which is as far as I know the blower.
My question is, could the problem be with the blower resistor ?
Thanks.
  • Views 1k
Have you had air con serviced??? Could be lack of gas or condenser problem
Sent from my SM-G900F using Tapatalk
Thanks for your answer,
yeah I'm pretty sure its low on gas, but this problem occurs even when its on ECON which as far as i know does not need the condenser to operate normally, or am I wrong?
Yes econ is to switch it off in that case could be the heater controls have you tried to unplug then reconnect see if that does anything
No, I didnt.
OK that sounds like a starting point, ill do that and see if i get any results.
Thank you.
