cutting compound for very light swirls
hi all,
i have very fine swirls and scratches on my bonnet and wanted to know what compound will help eliminate this.
they are not deep but quite faint - noticeable when the sun hits it or looking at in an angle.
the car is light blue.
i need something to use with the das-6 polisher.
clean your car do a range of kits...
http://www.cleanyourcar.co.uk/polishing-machines/das-6-pro-dual-action-polisher/cat_81.html
thank you.
  • Views 857
Are you using a DA or a rotary polisher to remove the swirls? I'd use some g3 and then g10 or some sort of glaze to finish it off :)
