6n2 central locking wiring connections at pump
just like to know which wires controls what as fitting remote locking and want to connect it to the pump wires in the boot
car already has factory central lock to it.
1: red/white (constant live)
2: red/white (constant live)
3: brown
4: red
5: empty
6: empty
7: yellow/white
8: brown
9: empty
10: green/white
11: yellow/white
12: black
thanks
  • Views 3.8k
1: red/white (constant live) FUSE 41
2: red/white (constant live) FUSE 41
3: brown GROUND
4: red PIN 5 OF DRIVERS DOOR LOCK ACTUATOR
5: empty
6: empty
7: yellow/white  WHITE/YELLOW  + 12v CLOSE SIGNAL FROM DOOR SWITCHES
8: brown GROUND
9: empty
10: green/white  WHITE/GREEN  +12v OPEN SIGNAL FROM DOOR SWITCHES
11: yellow/white OPEN SIGNAL FROM AIRBAG CONTROL UNIT TO UNLOCK DOORS IN THE EVENT OF A CRASH
12: black  IGNITION +12V SUPPLY FUSE 26
thanks
  • 6 months later...
Is the wiring of pump tha same in cars with CCM 6n0959799B ?
Thank you
Edited by cross95
