Engne codes (00518, 00530, 00533)
Hi all, had a few codes come up on the vag com the other day and wondered what I can do to sort them...
00518 - Throttle Position Sensor-Signal Out of Range(G69) Also check for loose ECM power relay
00530 - Throttle Position Sensor-G8
00533 - Idle Air Control Regulation
  • Views 6.7k
I would clear them, then re-scan in a week or so, as they might of been stored a while ago, that way you'll know if they return they are current faults, then we can go through the fault finding
Good shout. Thanks.
Old faults cleared.
Current actual faults are;
533 - Idle air reg
1087 - Basic setting not performed
New throttle cable fitted and throttle body cleaned, thoroughly.
Not sure where to go from here?
