disasembled distribution g40 1.3 py
Hi guys,
I'm assembling new distribution how to set it correctly on turbo converted car ? and i would like correct  ignition what would it be for an turbo charged g40 ?
Edited by lampik
  • Views 980
The base ignition timing will be the same for the turbo setup. So 5 degrees BTDC +/- 1 degree.
Once the base timing is set the ECU takes over after that and fine tunes it when under load.
or you could fit custom management  like megasquirt/megajolt/amethyst.
Some guidelines here (where I found that retard under boost really means  - do not advance as much).
http://www.useasydocs.com/theory/advrules.htm
and a useful initial map generator here
http://www.useasydocs.com/theory/spktable.htm
But Digifant will be hard to beat. Could upgrade the chip if made more mods eg
http://www.ebay.co.uk/itm/Volkswagen-VW-Polo-G40-Turbo-Chip-PPP-G40007/152115344149
Edited by dvderlm
