breaking silver 6n2 3 door 1.4
as title will probably be going to the polo show so can meet there if you want anything
will be best to text me as i will get back to you quicker o752795o59o
13315570_10208545179400803_710333580844013346619_10208545179480805_884705422819313346946_10208545178720786_2089406065485
  • Views 916
What the flexi pipe like going to the catalyst?  I could do with the pipe and cat.
 1.4 16v? Do you have timing belt case
How much for bootlid and where you based?
£35 I'm in Rotherham
Do you have the drivers side door wiring loom?
If so what conditions the wiring in between the door and the body?
If it's ok, how much would you want for it?
Hi, I'm looking for a clutch and both lambda sensors(pre-cat and post-cat) if you have these? Trying to fix an emissions MOT failure :(
