Mk2 1.3 Cyl Head torque setting and procedure
Hi,
Just had head skimmed after blowing a rad hose and small amount of oil in water, does anyone have the torque settings.
Ive looked in FAQ and can only find 1.0 engine - 30Nm, 90 deg 90 deg??
  • Replies 9
  • Views 3.3k
40Nm, 60Nm then +180deg according to Autodata
Ok Thanks.
Better to do the 180 degree in 90 degree stages, I didn't even do the full 180 because it was damn tight with the breaker bar already. Hasn't leaked yet but not sure how accurate my torque wrench is and I could have gone over slightly
Sent from my SM-G925F using Tapatalk
  • 2 years later...
Is this torque setting for the aav engine? Thanks
First Welcome to the forum.
Yes they are valid figures for the AAV
Ideal thank you so much 😀
  • 6 years later...
Is this also true for a GK engine?
Make sure you get the right length bolts. I had a bit of a struggle finding correct ones.
Yes, 40Nm, 60Nm, 2x 90° in a spiral pattern.
http://www.schraubmax.de/autodaten/vw_polo2_Coupe_GT_gk.html
