mk2f fox coupe breaking plus many spares/upgrades
I am selling up everything I have, the car is a 93 polo fox coupe in white, it suffered an engine fire and I have spent the last six months removing parts with the intention of rebuilding but I have decided that it will be too much work and I also came across rot in the drivers footwell
 I am open to offers and will post the smaller parts at buyers cost
£100
ABD 1.4 Complete block, think everything except head, starter and alternator
          Inc clutch, flywheel, sump, water pump and other parts, mounts, drive shafts
£50
GT 5 speed gearbox (cleaned up)
£200
GT Camshaft and pulley
GT head (skimmed, light port and polish, may have new valves and seals)
£50
6n Polished cam cover
£20 each
2x Gearbox mounts
£currently under offer
Spare set of jets for CBR bike carbs (can’t remember size)
CBR400 AND CBR600 bike carbs (1 in parts following clean and new screws)
CBR air box fitting plate and rubber hose mounts
Assorted fuel pumps, filters etc for carbs
NEW 2m cable for bike carbs
NEW Facet fuel pump kit
GT inline fuel pump
Impact fuel cut off switch for safely running bike carbs
£150
R6 Carbs complete on manifold for 8v engine with fuel pipe work and filters, pumps etc
Polo mk2 vac advance dizzy setup inc loom, coil, dizzy ect)
£25
GT Engine loom
£? I’ll see what there is when I’ve cleared some parts
Various fluids and service parts
£under offer
NEW BOXED Newman 270 Camshaft (recommend by newman to match spec)
£25
NEW GED style lower brace bar (new black)
£10
Polished front lower strut brace (damaged but functional)
£20
Arb block mounts
£5
NEW TCA poly bushes (needs metal inserts)
£50
GT rear arb beam (painted black with 10mm widening plates welded on ends)
£25
Genuine VW optional extra rubber mats
£20
Full set of exterior bump strip trims
£5
Spare spoiler
£free
Boot interior trim panel (not perfect)
£free
Gutter trims         (small cracks or splits)
£10
Heater fan box with good resistor
£30 the lot
2x Tubs of mixed trim and small parts inc 2 soapbar mirrors (drivers), standard mirror, standard fox steering wheel, 4speed gearknob
£15
Genuine BMW bumper vents that fit in the fog light blanks on these polo bumpers (roughly sanded and painted satin black)
£20
undamaged badged grill
£20
Mk2 Drivers door (painted LOCTITE appliance white rattle can paint)
£20
Mk2f Passenger door (painted, LOCTITE appliance rattle can paint)
£20
Bootlid (numberplate recess and holes welded over amd 6n 3rd brake light fitted, needs finishing/re-smoothing)
£20
Windscreen (un-marked)
£200
4x 14 or 13” Banded steels 7” and 7.5”ish (rough lips and 1 is odd, tires low tread)
£300 or nearest offer (cost £800 inc labour)
Full stainless custom exhaust, exhaust uk/cobra, 3” tip and stainless 4-2-1 manifold
          PARTS STILL ON THE CAR
£50
80/60 ta techniks suspension used
£50
OMP drilled and grooved discs, ebc greenstuff pads, hel white braided flexi lines and vw2 callipers painted white hammerite
I also have almost all polo parts so feel free to ask inc two sets of fox interior which together make a very tidy set, a set of black carpet door cards, a momo steering wheel and matching boss, black parcel shelf with splx speakers fitted, 2 front bumpers, 1 rear, all glass plus extras, fox steels with custom rattle can paint
I am trying to get all parts off the car but am having some problems
  • Replies 112
  • Views 10.7k
  • yorkshirevw
    yorkshirevw
    £5 plus postage
  • yorkshirevw
    yorkshirevw
    I can't confirm if it squeaks as I bought it to replace mine and never fitted it, it has a good resistor and comes as seen.
  • Heater motor received. Many thanks, as described, fair price and received quickly
Forgot to say the car is located in South Elmsall near Doncaster
a pic of the exhaust fitted and how the smooth boot used to look before I ruined it.
Edited by yorkshirevw
Adding location
Hi have you any photo's of the vw floor mats please ?
i'm after the body trim that goes between the rear bumper and
the bodywork, for the off side. maybe other bits cos we have 3 mk2f coupes.
where in yorkshire are you ?
ta
not at the moment but I'll get some tomorrow
ta
I've that trim still on the car but it has some paint on it from when I sprayed a bumper and old trim black and the car is in South Elmsall near Doncaster
how much ? no rush for it, the car aint on the road atm
hi there do u still have the suspension ??
£5 plus postage
Yep but still on the car, I know I can get the rear off easy but not sure about the front, having problems disconnecting the flexi line and some steering parts.
Thank you ..
£5 plus postage
sold ! let me know your paypal ID and i'll get the £ transferred
ta
not perfect but no damage.
Ok can you pm a price posted please ? Thank you :smile:
postage will be expensive, they are heavy and however i pack them it will be large.
You going to any show's this year ?
I've non planned, need the money to get another car when the polo's gone
NEWMAN CAM SOLD!
spelling
Without taking the piss can you get me a rough quote on P+P please ? if not no problem we leave it as you said it might be to much on P+P ..
I will if you want, it may be Friday. pm me your postcode and I'll check online hermes.
Been back down to mess with the car today
semi-shiny gold coloured door catch things £5 posted
Custom Rat-look sun visors £5.
front crash bar in good condition (front bumper bolt brackets knackered though £10
I'll do the brake setup for £25 as the flexi's are stuck on to the copper pipes, the pads are pretty worn and one of the calipers has a small chunk out of the very edge (this won't effect the braking)
Hi did you get my paypal payment ok ?
FLOOR MATS SOLD
ALSO NOW AVAILABLE
£100
GT inline fuel pump
lowered price
wings £10 the pair
rear bulb holders with mostly good bulbs £5 each
arb £5 (also have poly arb bushes £5 pair)
steering arm £5 if it's any good (the wheel arch end bolt is at an angle)
two front bumpers (one has been rattle caned in the past and both have slight damage to side mount £15 each
rear bumper £15 melting under exhaust cutout
radiator and fan assembly £15 (some damage to radiator fins)
Will you do a deal on the arb blocks and GED brace posted?
