mk2f fox coupe breaking plus many spares/upgrades
8 hours ago, Qwerty said:
Will you do a deal on the arb blocks and GED brace posted?
Yeh sure, Message me what you are thinking, Notice in the arb pic that the rings used to stop the bar moving in the mounts won't come off.
  • Replies 112
  • Views 10.7k
  • yorkshirevw
    yorkshirevw
    £5 plus postage
  • yorkshirevw
    yorkshirevw
    I can't confirm if it squeaks as I bought it to replace mine and never fitted it, it has a good resistor and comes as seen.
  • Heater motor received. Many thanks, as described, fair price and received quickly
PRICE LOWERED ON
gearbox mount £10
gt loom £20
gt beam £40
spare spoiler £0 it's been semi smoothed
grill £15
btw
if anyone knows how I can edit my original post let me know
PM sent re editing :)
Hey,
have you still got the rear lights not the holders the lenses and would you happen to have the interior door handle cable ?
10 hours ago, iccledude said:
Hey,
I've an orange set of rears left and I've loads of spare door bits as I scrapped two doors, which bit do you need?
right Ho, I shall leave the lights then, could you give me a price for the inner door handle cable from lock, 2 grommets for the outer door handles and a n/s window reg posted to sa1? :)
muchos gracias porfaor
Edited by iccledude
By window regulator do you mean a specific part or the whole mechanism?
and don't think I'll have any handle grommets as they perish, I'll have a look in my bits boxes though.
Yeahh the whole thing please :) plus what about the door lock cables too ? :)
I have all internal parts, I'll have to figure out how to package them and get a postage quote. I'll take £5 for the parts minus postage if it's just one doors parts you need.
Ok bud so when you have them all packaged up and the full figure with postage, pm me your details and I'll PayPal the money over
plus could you throw in an inner door handle surround if you have one,
and to recap the other part just so we are clear
window reg And door lock cable
many thanks
On 17 July 2016 at 12:31, yorkshirevw said:
Yep but still on the car, I know I can get the rear off easy but not sure about the front, having problems disconnecting the flexi line and some steering parts.
are they in good condition ?
see the pic on page one for the brakes, they aren't great but okay, vw2 callipers okay except for a small chunk off the edge, pads worn, discs rusted from being sat, flexis good but attached to copper pipe still.
On ‎16‎/‎07‎/‎2016 at 16:01, yorkshirevw said:
I am selling up everything I have, the car is a 93 polo fox coupe in white, it suffered an engine fire and I have spent the last six months removing parts with the intention of rebuilding but I have decided that it will be too much work and I also came across rot in the drivers footwell
 I am open to offers and will post the smaller parts at buyers cost
£100
ABD 1.4 Complete block, think everything except head, starter and alternator
          Inc clutch, flywheel, sump, water pump and other parts, mounts, drive shafts
£50
GT 5 speed gearbox (cleaned up)
£200
GT Camshaft and pulley
GT head (skimmed, light port and polish, may have new valves and seals)
£50
6n Polished cam cover
£20 each
2x Gearbox mounts
£currently under offer
Spare set of jets for CBR bike carbs (can’t remember size)
CBR400 AND CBR600 bike carbs (1 in parts following clean and new screws)
CBR air box fitting plate and rubber hose mounts
Assorted fuel pumps, filters etc for carbs
NEW 2m cable for bike carbs
NEW Facet fuel pump kit
GT inline fuel pump
Impact fuel cut off switch for safely running bike carbs
£150
R6 Carbs complete on manifold for 8v engine with fuel pipe work and filters, pumps etc
Polo mk2 vac advance dizzy setup inc loom, coil, dizzy ect)
£25
GT Engine loom
£? I’ll see what there is when I’ve cleared some parts
Various fluids and service parts
£under offer
NEW BOXED Newman 270 Camshaft (recommend by newman to match spec)
£25
NEW GED style lower brace bar (new black)
£10
Polished front lower strut brace (damaged but functional)
£20
Arb block mounts
£5
NEW TCA poly bushes (needs metal inserts)
£50
GT rear arb beam (painted black with 10mm widening plates welded on ends)
£25
Genuine VW optional extra rubber mats
£20
Full set of exterior bump strip trims
£5
Spare spoiler
£free
Boot interior trim panel (not perfect)
£free
Gutter trims         (small cracks or splits)
£10
Heater fan box with good resistor
£30 the lot
2x Tubs of mixed trim and small parts inc 2 soapbar mirrors (drivers), standard mirror, standard fox steering wheel, 4speed gearknob
£15
Genuine BMW bumper vents that fit in the fog light blanks on these polo bumpers (roughly sanded and painted satin black)
£20
undamaged badged grill
£20
Mk2 Drivers door (painted LOCTITE appliance white rattle can paint)
£20
Mk2f Passenger door (painted, LOCTITE appliance rattle can paint)
£20
Bootlid (numberplate recess and holes welded over amd 6n 3rd brake light fitted, needs finishing/re-smoothing)
£20
Windscreen (un-marked)
£200
4x 14 or 13” Banded steels 7” and 7.5”ish (rough lips and 1 is odd, tires low tread)
£300 or nearest offer (cost £800 inc labour)
Full stainless custom exhaust, exhaust uk/cobra, 3” tip and stainless 4-2-1 manifold
          PARTS STILL ON THE CAR
£50
80/60 ta techniks suspension used
£50
OMP drilled and grooved discs, ebc greenstuff pads, hel white braided flexi lines and vw2 callipers painted white hammerite
I also have almost all polo parts so feel free to ask inc two sets of fox interior which together make a very tidy set, a set of black carpet door cards, a momo steering wheel and matching boss, black parcel shelf with splx speakers fitted, 2 front bumpers, 1 rear, all glass plus extras, fox steels with custom rattle can paint
I am trying to get all parts off the car but am having some problems
A few more pics of the stuff.
More bits removed from the car.
1.0 aau bottom end, head available.£20 with head.
bottom cross member that radiator sits on. £5
Hi I've messaged you... but I'm new here so I may not of also... please let me know if you've got it.
I've just acquired a 1994 MK2F polo which i'm getting ready for my partner to use as a 1st car/learner. I've done most of the mechanical work on it but need the following bits if anyone has them..can collect from most areas with a bit of notice.
Door Mirrors
Fuel Pumps (both have a terrible whine)
Full interior (seats, door cards etc as car was used as a work van and they are knackered)
Rear lights
Anything else you have as these cars are getting difficult to find parts for.
 Many thanks!
Door Mirrors
Rear lights
 Many thanks!
I've two fox rear seat benches and maybe a passenger seat, all in very good condition, both pumps are still on the car but I'll look at getting them off this weekend, I've drivers mirror in standard shape (non cable adjust) and a soapbar shape and a set of the original/early orange spec coupe rear lights
I also have a set of black carpet door cards which aren't great (faded) but look okay and maybe a set of fox door cards minus passenger
Door Mirrors
Rear lights
 Many thanks!
Got the pump and filter assembly off £15 the lot, mount has been hammerited so is solid
Rev counter clocks, front panel has hole for a speedo reset, I've the original speedo to match but the one I fitted doesn't have £10
i'll take them clocks, posted price ?
cheers
hi mate , any news omn getting the suspension off?
could you please send me some pics of black carpet door cards and the fox steels please..
I'll get some pics of the door cards later, they are on the other computer
just to give you an idea before I cleaned them up, this was the worst.
Edited by yorkshirevw
Ok nice one thanks
Sent from my SM-N9005 using Tapatalk
